Just blown my Harbs....
Ian
5,412
3,495
United Kingdom
Ian
No, not had oral sex with them, setting up my squeezebox and connected it to the 'Out' which means everythong my Croft 7 has went into them. Ho hum. So, estimated damage and costs anyone ? I'll be phoning Harbeth towers tomorrow. Erm, sad face !
meninblack
22,674
1,107
Your Croft only has 50W, which shouldn't be anything like enough to damage the speakers. Or did you somehow mis-connect them? :dunno:
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
I'm not sure what your saying Ian. Do you mean that the SB was outputting at the time you connected it and that the amp was open circuit? giving a very loud blast of output?
Reactions: Ian
Ian
5,412
3,495
United Kingdom
Ian
The HiFi was already set up and working, has been for ages. I was installing the Squeezebox anew after having it stored after moving. The Croft pre has an 'Out' next to the pre out and I connected it to that. I'll check the valves on the amps. and see if I can get the speakers connected to another system somewhere. Doug, help !! I'll PM you.
Bourney
8,003
483
stoke on trent
Steve
Sure your amp has gone into 'protection' type mode Ian? My rega monos did this a few years ago. Took my speakers to the dealers next day and by them the amps had reset themselves somehow. I dropped an interconnect while fiddling arou d without switching off.
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
Nottingham?
Welcome here. I can put them on a tranny amp with relays to test them and go onto the tube amps after. Half hour up the road if I've got your location right.
meninblack
22,674
1,107
Are you saying you connected the power amp to the "OUT" (= full volume to the speakers) or that you connected the Squeezebox to the "OUT"? Either way, you shouldn't damage the speakers.
AmDismal
9,277
134
If you connected the SB to an output of the pre-amp, I doubt you'd kill the speakers.
If you have somehow managed to put a full volume signal into the speakers, you could easily damage the tweeters; 50W could also do some damage to the bass units as they are not designed for much power.
Can you describe more clearly exactly what you did, and what sound (if any) you are getting?
Nagraboy
5,705
607
Nottingham
Greg
I'm a bit confused too; hope the Harbs are ok Ian.
meninblack
22,674
1,107
Harbeth website rates them as 50W continuous, so a short burst shouldn't damage them, surely?
Bourney
8,003
483
stoke on trent
Steve
An amp out putting full power will be distorting and that's what will nadge the speakers. Still don't quite understand what connecting an input into an output will do to the speakers.
Ian
5,412
3,495
United Kingdom
Ian
Connected the SB to the out, loud distorted music. Played CD afterwards and just now and getting music but very distorted. It's either the speeks or a valve. I'll get the speakers connected to another system first and go from there.
rockmeister
18,004
745
Scotland
sounds like one of those loud hum/bangs when shorting..huge peak of noise, but the actual effect might be more likely to have blown an amp fuse or, as someone said, tripped a protection circuit. Read the manual to reset it and test all the fuses then try again. GENTLY! :)
Aha,,we posted at the same moment.
That doesn't sound too clever. Good luck!
meninblack
22,674
1,107
Sounds more likely that you've damaged the pre by short-circuiting the output.
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
My thoughts too. Ian is in my back yard so to speak, and I have enough bits here to sort the process of elimination. Including a s/s power that will handle a dead short without becoming a victim :^
undarra
313
41
43
Nr Portsmouth, Hants
Si
Hi Ian
Before you get too distraught check all of the fuses on the back of the crofts. There are three on the back of the power amp. I had a similar sound issue after a 'bang pop' moment and feared the worst. I contacted Glenn and he said check the fuses. Why I didn't think of this I don't know! They are a funny value 6.3 amp I think. I found some some at maplin though. If its that and you can't find any I could send you one. Fingers crossed for you!
Cheers, Si
Reactions: Ian
ridley
1,008
28
Leicester, , United
Simon
Ian, did a similar thing with my Croft once, it took out one of the fuses on the rear panel. The result was distorted music & wouldn't play at normal volume. I think/hope this is the problem.
Regards Simon.
Ian
5,412
3,495
United Kingdom
Ian
Thanks Simon and Si, there's hope yet. Will report back of course. And thank you so much Rick, will contact you tomorrow. I'll either get fuses from Maplins (they're not 'normal' size) or check out my speakers fist.
The 'Wam helps the foolish ! If it's a fuse I'll be bloody relieved I can tell you.
