As long as you’re happy.No. The room modes are unaffected by the speaker. My room is not ideal but is sounds amazing with DSP.
The system was especially designed for such customers.
All that matters is one’s own enjoyment.
Different speakers will of course not change the room nor its mode frequencies, but they will be excited in different ways. Add in the power amplifier that tries to keep bass drivers under control, thus counteracting the room's resonance, and you see why different speaker/amp combinations sound differently in the same room. And why the same speaker/amp combo will sound entirely different in another room, or even if placed differently in the same room!No. The room modes are unaffected by the speaker. My room is not ideal but is sounds amazing with DSP.
Congratulations on your purchase! The 350 is not a very easy speaker to setup, but great rewards in term of musicality await you if you got it right. My experience is they like lots of space around them, and when using so(+) it is critical to enter the right degrees of toe-in (that is, if you are going to apply toe-in at all). To improve further you could place them on GAIA I feet. Since these will compensate for any resonance, the result will be that the 350 is absolutely fixed in place which enables them to shine even brighter!Ok, I bought them. It's an Artikulate 350 upgradet to Klimax and sold as Klimax 350 by "Best Sound in Hamburg in 2011"
Had a listen (without the stands so it was more of a function test) at Eksakt HiFi in Oslo yesterday and it was promessing engaging (New Selekt DSM with Organic and a pair of Klimax Solo). Stands are on their way.
Are about to upgrade them to Exakt (will order the card for the bass units) and use my Akurate Exaktbox 10 Katalyst with Selekt DSM (currently with original PSU) and 2xAkurate4200. Main source is Limax LP12.
I currently use these electronics with Majik Isobarik and the difference to another room where I have another set of MISO with active bass and M6100 (using 4 channals) and AEDSM/1 (Majik LP12, Lingo4, Akito3) is staggering.
For a period I used the main excakt system and the M6100 into Akubarik but never got happy (actually was a bit boring) but I later discovered that this was due to 1)AEDSM as hub 2)Naim Fraim on Linn electronics, and the mix of amps.
Quite excited about this. Getting the speakers delivered on Wednesday - first to be used passive while waiting on the card.
That’s exakly right—-or we would all own the same speakers which is no fun at all!Sorry, I really don’t hate them. They are good speakers but for me, not the most musical one.
Bit don‘t worry….tastes are different.
When I first got my 350p's I used two channels from a A3200. I then got hold of a cheap older Klimax Twin (TBH Mostly for aesthetic reasons) and wasn't expecting much sonic improvement but I was nicely surprised. Worth it if you get the chance - Solo's would be even better.two channels on a 2010model Akurate 4200
Hi, I've got the following alternatives:When I first got my 350p's I used two channels from a A3200. I then got hold of a cheap older Klimax Twin (TBH Mostly for aesthetic reasons) and wasn't expecting much sonic improvement but I was nicely surprised. Worth it if you get the chance - Solo's would be even better.
