Hi guys,
I'm seriously considering my final upgrade jump, Akurate LP12 to Klimax LP12. Speakers and DSM are already at Klimax level. So now I'm curious whether to choose Urika 1 or 2. I'm closer to Urika 2, as it would be pefect match.
However two things bother me.
First, ADC imbeded in Urika 2. I assume Urika 2 has two ADCs which are at least one generation older than ADC imbeded in my Klimax NG DSM hub. Should I now expect maybe better results with analog Urika 1 coupled with NG ADC? I also assume the Urika 2 ADC board will soon be upgraded... but so far ADC board inside Urika 2 is the old one.
Second one is less important, but still IMHO valid - my Klimax LP12 will work only with Linn (exakt) systems , and I will not be able to try and compare it with any other system. Exept parhaps via optical out which I have spotted on Urika 2. Otherwise no analog outputs at all.
Your thoughts on this dillema would be much appriciated
Best Regards and Merry Christmas,
NL.
P.S. I need a phonostage now, as my KDSM doesnt have it inside. I use my old Akurate DSM/3 as "phonostage", connected to KDSM via optical Toslink. I found this connection sounding better than analog, and better than SPDIF digital. I did't try exakt, as on both Akurate and Klimax DSM there are only male exakt link sockets. But anyhow its pointless to use Akurate DSM like this. My other thoughts go into direction to leave Akurate LP12 as is and to add Lejonklou Entinty.
NL.
