Leak TL12+ Rebuild
Radford Revival
231
36
58
South West
Will
Hi everyone,
I am in the process of restoring a nice pair of Leak TL12+ amplifiers. I've taken pictures of my work so far in case anyone is interested.
Here they are, in fairly untouched original condition. There were a couple of bodges underneath but luckily nobody has butchered the bodywork.
Quite nice looking amps with valves in.
Underneath
Rear of one
Close ups of underneath
Reactions: AGrail
Radford Revival
231
36
58
South West
Will
Fast forward a bit and here we have all the passives replaced :party:
As you may be able to see in the previous pictures, the original smoothing caps were a bit knackered. As they are part of the amplifier's "look" it was necessary to keep the original cans. Luckily modern electrolytics are physically smaller so it was possible to strip the original capacitor out (a messy job :nup: ) and fit a new one in.
A bit of creativity with a saw, large pliers and potting compound leaves us with this (cable ties for keeping them central long since removed!):
Valvebloke
Member
4,432
274
Didcot, Oxon
Nice work Will :^ , and nice amps. People sometimes describe these as being like a Stereo 20 split into two monoblock halves. But they're not really. The Stereo 20 has an all-triode front end whereas the TL/12+ has an EF86 feeding an ECC81. This pentode/double triode arrangement echoes the TL/12 Point One circuit which, of course, the TL/12+ replaced.
VB
Radford Revival
231
36
58
South West
Will
Nice work Will :^ , and nice amps. People sometimes describe these as being like a Stereo 20 split into two monoblock halves. But they're not really. The Stereo 20 has an all-triode front end whereas the TL/12+ has an EF86 feeding an ECC81. This pentode/double triode arrangement echoes the TL/12 Point One circuit which, of course, the TL/12+ replaced.VB
Interestingly the phase splitter circuit uses the same resistor values / topology as the ECC83 splitter in the Stereo 20. Not having drawn any load lines I suppose it's just a happy coincidence the the same values bias both valves correctly.
pure sound
8,762
217
West Devon
Nice neat work again :^ Did these have the same 'resistor as fuse' arrangement as the ST20? Can't tell from the pics. Presumably these were originally sold as Mono amps (with mono pre) & pre-date the ST20.
Radford Revival
231
36
58
South West
Will
Hi Guy,
I hope to work a fuseholder into them eventually, as far as I've fiddled with I have yet to find a convenient place. Due to the constraints of where things fit I may just have to fuse the output stage by itself, but of course that's the most potentially destructive bit by far.
Valvebloke
Member
4,432
274
Didcot, Oxon
In that circuit the ECC81 runs at very low current - only about a milliamp per triode. This drops the gm and raises the anode resistance to values which are much closer to those of the ECC83. The mu's still differ by nearly a factor of two of course. But what's a factor of two between friends ...
VB
Radford Revival
231
36
58
South West
Will
Had some bits made! Mode pictures coming soon. We will be eventually offering these bits for sale for your Leaks. We will also be producing Stereo 20 bits.
The black pieces are to fit Cliff binding posts, and the rectangular black piece is to fit a toggle mains switch in place of the external mains supplies which no one in their right mind would use anyway! These will also fit on Stereo 20s. They were made so the original plastic bits can be kept aside if one wants to return to original condition. They are not yet fitted in the pictures below.
robin
Good bye
4,765
1,321
like the base plate, good idea, will be after one for my 20
No members online now.
