1) In the manual it says when hooking up a 2nd Linn subwoofer to daisy chain them. It shows AV processor to Sub 1 and then Sub 1 to Sub 2. The Linn Kisto has 3 sub outputs though and the ability to program it for 1,2 or 3 subs. Any idea which hookup method will perform better for 2 channel and 5.2? Also, if I do the daisy chain method, only one sub output on the Kisto will be used so would I program the Kisto to have 1 or 2 subs?
2) Positioning tips? The manual just says put it close to the front L or R speaker. No tips for dual subs. Are you guys putting one by each? Next to the speaker or behind it?
3) I have two Sizmik 10.25’s. On one the fan comes on often and is a little annoying. I think it might be an earlier version than the other. Anyone else know anything about this issue?
4) Anyone a fan of using “Stereo Sub” mode for 2 channel listening? Any tips on maximizing setup for this?
Thanks in advance for your help.
