Looking for a powerful tube integrated...?
newlash09
3,304
3,167
45
India
Y.Manohar / mike
May I know which speakers you are using please. I've used high powered tubes in the past like KT88 and KT120's. And atleast to my years they sounded more like the class A power amps I've previously had. So in summation, I would stick with class A, and get rid of the tube replacement and biasing ritual, if I needed lots of power. But how much will depend on your speakers and your room size sir.
Jules_S
Are we there yet?
3,085
Southampton
Jules
Quite frankly for £21k I'd expect far more than dodgy manual bias adjusters that are difficult to set and won't stay as they should (according to the review anyway). No excuses for that sort of shonky quality on an amps at a tenth of the price, let alone that. There are other higher-powered valve amps that are easier to own and use
Jules_S
Are we there yet?
3,085
Southampton
Jules
I was just posting to show its power not the review.
Fair enough, I get it. I shouldn't imagine the tube life is going to be terribly good, running them that "hot". My Primalunas were the opposite end of the scale, getting around 85W per channel from a quad of KT120s in ultralinear mode so not stressing them too much. I suppose if you're dropping that sort of money on an amp, an annual octet of output valves is likely to be pocket change
Psilonaught
3,610
2,103
Saffron Walden
£21k for a pentode amp WTF!?
For that kind of money of be looking at atma-sphere ma2 amps or the big NAT amps, both over 150w and triode based.
Colinjg
Legend Wammer
7,169
4,372
South Midlands.
Walter Fagen.
Maybe off topic but Valve Pre with SS power can be a brilliant combination. Whether an integrated or separates. imho.
Reactions: hiesteem
hiesteem
peacebro
1,746
1,461
133
Pete
Vincent make some solid tube amps. Pre, power and integrated. The latest SV 737, looks good value 180 watts per channel into 8 ohms.
akash011
