Marinade for a boned shoulder of lamb on BBQ
G
Not sure which way to go with this marinade. Any suggestions?
As most of the week looks good can do long marinades too.
Cheers :^
Ozexpat
15,542
272
the brewhouse
I would go Greek. Olive oil, lemon juice, garlic and oregano. It's a classic that we used in Oz when spit roasting. Use it to baste as and when.
Another would be Greek yoghurt, chilli, ginger, garlic, corianda. As much or as little of each as you like. Lay it over and roast or BBQ. It goes crispy in parts and unctuous in others without disguising the wonderful lamb flavour.
Professor Chaos
4,912
54
Toronto
Kelley
Soy or teriyaki sauce, dry sherry, lemon juice, minced gingerroot, crushed garlic, sliced green onion, and some cracked black pepper.
Craig
6,364
318
Copenhagen
Craig
I'd quite fancy a moroccan rub (where's Pierre?) but most of all I'd be cooking it as slow as possible off the heat, with some sugar in the rub to ensure some colour to the finish. And it's only done with the thermometer says so. Then rest.
I find lamb a bit of a BBQ PITA to be honest. At least, when other people cook it. I always get served a lump of charred crust meets raw as buggery inside.
Craig
6,364
318
Copenhagen
Craig
I would have thought a shoulder of lamb would be too fatty to successfully BBQ.
I dunno about others, but I cook loads of fatty meat on the BBQ and it's fliipping lovely IMHO. I like brisket and pork neck & belly. Just needs cooking with not so much charcoal, indirect heat and lid on. Leg of lamb isn't really that fatty, is it? Aside from the skin, obvioulsy.
johnniebaby
18,013
201
Midlands
No, but he's talking about shoulder.
Craig
6,364
318
Copenhagen
Craig
My bad, you're right.
Doesn't make much difference though, can still be cooked wonderfully on BBQ. So long as the meat is cooked long /slow the sinew and collagen will break down into gelatine *licks lips*
MF 1000
Extreme Full Range 😱
6,171
4,731
Caego
Keith
If you have the kit....vacuum pack the shoulder with the marinade ....cook in a large pan of water at 70 deg c for 3hrs then flash roast it on the BBQ
HoopsOnToast
Legend Wammer
11,626
808
Oxfordshire
Rob
I would go Greek. Olive oil, lemon juice, garlic and oregano. It's a classic that we used in Oz when spit roasting. Use it to baste as and when.Another would be Greek yoghurt, chilli, ginger, garlic, corianda. As much or as little of each as you like. Lay it over and roast or BBQ. It goes crispy in parts and unctuous in others without disguising the wonderful lamb flavour.
That would be my choice, I have found a good alternative:
Cumin, Garlic and Thyme with LOADS of olive oil.
Done this many a time as a base for a good curry (previous bake off) :^
A
avole
I would go Greek. Olive oil, lemon juice, garlic and oregano. It's a classic that we used in Oz when spit roasting. Use it to baste as and when...
This, but I'd slice the garlic finely and make a number of small cuts in the meat into which you insert the garlic having rubbed in the marinade. This helps bring out the flavour of the garlic a bit more.
G
Forgot about this thread. In the end I did the greek yoghurt coriander chili ginger garlic approach. So cheers for the tip.
A boned shoulder is perfect for the bbq as long as you don't cook it when the charcoal is too hot, I did after after cooking some home made burgers, sausages and steak so by the time you put the lamb on the charcoal is a good temp. The fat keeps it seriously tender and with the lid on it doesn't need much attention and always works.
