U
Umberto
Where to start????
This is simply the most liquid velvety sounding system i have ever heard. I don't know if its the "valve" sound or if its the Mahi - Shrimp combination but TBH there could be pixies inside it. I don't care.
The sound is very natural and smooth but not at the expense of detail. It also matches well with the Arts. If you think Art speakers are bright sounding look at the partnering equipment, not the speakers.
It possibly dosen't have the absolute grip of the Bow and this is most noticeable in the bass but the bass is very natural sounding and there is plenty of it. There are two modes you can use the Mahis in. Triode and ultra linear. Triode mode is supposed to sound better but in my systemIprefer it in ultra linear mode where it has a little extra grip (in Pauls system i prefered it in triode mode but maybe thats got something to do with the speakers).
Having heard a number of valve setups including VTL and Prima Luna, which failed to impress, the Mahis and Shrimpreally are something elseand the Aria just lets them do their stuff.
I also havean Isotek Nova to floss the mains and, according to Paul,helps with the low-level detailin the system. I haven't tried it out the system yet so I can't verify this.
Try to get a listen to this combination if you can. Its not that expensive for what you get.
Umberto
Umberto
