Excellent. Now to sync your Bank Account (so it takes another decade to recover).We are syncing or agendas![]()
You’re rightGreat to get your view - and it very much matches that of @ChemMan
My initial thoughts would be:
- I would not commit to a Source until the work has been done on your Amp. It "could" effect your decision.
- The Pulse will improve any DAC that is plugged into it - so could well be the first thing to get.
- Make sure the more detailed sound of the D2 doesn't become tiring after some time, on some recordings. Listen to some of your worst recordings
- Another course of action would be to get the Holo May (Level 2 or KTE) to try - then you could switch between genuine NOS and Upsampled, depending on mood and music. If keeping the TT, this could be a happy medium between the Spring and the D2.
Holo May L2........€5319 (with the Pulse is €580 cheaper than D2 alone)
Holo May KTE.....€6349 (with the Pulse is €450 more than the D2 alone)
Nb. You are right to worry about overloading your room with bass - and the upgraded 35i could affect this either way.
I would be completely amazed if the sound of your amp is messed up. It will sound the same, only much better (that sounds a bit Irish - but you know what I mean).You’re right
The work on the AMS is for the weekend of August 15
Hope it will not mess my amp sound
Because sinds I took it out of the rack, it’s back. I guess it just needed more breeding room
I looked in to Holo May as well more precisely the level 3 an the Katsunune edition (6800€ +- with pc an upgraded fuses)
The same version of the Spring is 3300€+-
One of my Next action will be take a trip to Heilo 230km Magna hifi stock both
Other thing that make me hesitate is I’m pretty sure I get a nice discount on the D2 not sur about Holo
This of course influence my decision process
Just talked to Alex an he suggest Spring - Pulse. He thinks the D2 is way to expensive
He is provably right…. He make me come back to reality for a sec will depend also on discount I get of course
@ChemMan I think I should pay you a visit see what the pulse could do on the Moon
If that good it really will give me some time to chose my dac
Nicely summed up at the end of the article:For those who are interested ( use Google translate ) found this quite interesting on my journey
https://www.hifistudio79.nl/musician-r2r-multi-bit-ladder-dacs-vs-delta-sigma-dacs/
"The sound of the Ladder DAC is more natural and musical in a sense, according to many, the Delta sigma is more direct and honest, which one is the best? Fortunately we do not have to make that choice, the best is the dac that you as a customer like best."
Yesterday at a moment I said if we could mix both dacs we would have a perfect dacAnother course of action would be to get the Holo May (Level 2 or KTE) to try - then you could switch between genuine NOS and Oversampling (boosted by HQ Player if necessary), depending on mood and music. If keeping the TT, this could be a happy medium between the Spring and the D2.
IMO. To spend the money on the D2, it needs to "wipe the floor" with the cheaper competition in all areas ie. Not have areas where the Spring sounds better.Yesterday at a moment I said if we could mix both dacs we would have a perfect dac
Based on what I read and of course taking it with some serious questions the May might just ad the controle an detail I was m slightly missing than again that miss disappeared after 30min an I was just enjoying the music
So this could be an option
Any way for now I keep all options open
What changed?
Well D2 is still the one but not all the time wel technically yes but today I’m thinking om some tracks the spring better match my taste on others the spring was to much overwhelming for me
I guess I will take that trip hopefully I can compare spring an May
Even if it’s not in my system it will give me an idea of what to expect
An maybe I can get some kind of arrangement if I drive over there an talk to the guy
Hue have no bass issue with the D2 that’s the only part where it’s a little to dryIMO. To spend the money on the D2, it needs to "wipe the floor" with the cheaper competition in all areas ie. Not have areas where the Spring sounds better.
Correctly spec'd Acoustic treatment, along with the set up of the speakers improved - will take care of the worst of your bass issues.
I've found the ESS D/A chips ‘bright’ compared to the more neutral AKM and slightly’dark’ BB/TI but they were in DACs from different manufacturers. It would be interesting to compare the top AKM and ESS versions of the ADI-2 DAC and the D90 because both manufacturers were forced to replace chips after the AKM fire but made no other changes...Hue have no bass issue with the D2 that’s the only part where it’s a little to dry
The rest is damn amazing
Btw the D280 is kind kind of the same on the bass part
Maybe it’s a carateristic of the saberdac…
How does having the spikes in place affect the Bass?Hue have no bass issue with the D2 that’s the only part where it’s a little to dry
Didn’t do that yetHow does having the spikes in place affect the Bass?
Have no experience with AKMI've found the ESS D/A chips ‘bright’ compared to the more neutral AKM and slightly’dark’ BB/TI but they were in DACs from different manufacturers. It would be interesting to compare the top AKM and ESS versions of the ADI-2 DAC and the D90 because both manufacturers were forced to replace chips after the AKM fire but made no other changes...
It is all to easy to get caught up in the analysis, the decision, the second guessing yourself and the worry about the cost - that you become too stressed to enjoy the music. This even happens with one's own system if not in the right frame of mind.I needed a break this evening
Wasn’t enjoying the music anymore
The exceptional sound of the D2 wasn’t there anymore. I Was tired, to much thinking, analysis… the music was far away
A headache overthinking everything.
Hopefully a fresh mind tomorrow
Because it’s the last day, an this device might be overpriced, it is truly special in the way what it does in my room how it fill it
