My new system: Rega Planet 2000, Naim Nait5i, Dynaudio Contour 1.3MKII, Atacama SE24, VanDamme 4mm, QED Quinex 2.
The stands are fully sand filled, position is slightly toed-in, they are placed close to the wall for extra bass effect, the grilles are left on because I think it slightly reduces the brightness.
Well, I sat and listened for most of today continuously, here are my observations, I'll run through the tunes I listened to so you can see where I'm coming from.
1. Overlap - Tracks 4 & 8, Transformation & Ghost Story.
http://www.saikosounds.com/english/display_release.asp?id=3836
This is full-on Psychedelic Trance - the tracks start with deep swirling basslines and as you may hear from the samples, the tunes contain a fast, pounding beat but with plenty of high-frequency sci-fi noises and sounds over the top. There are many layers of sounds and definately, from listening to this kind of music through loud outdoor rigs, I've found that it's the mark of a good system that can keep the layers differentiated and let you hear the individual noises but at the same time, not be too clinical so that you can still dance and get lost in the track.
Unfortunately, I found my system wasn't too hot on this. The bass was fine but I found all the sounds got a bit muddied and I felt the system was struggling to keep up with it all. Myears also felt a bit tired afterwards, the high-freq noises and melody lines seemed a bit too bright and forceful.
2. Nick Cave - Kingdom,
Bjork - Unravel,
Lamb - Gorecki, - all of these I've grouped together as they are all soft, relaxing, emotive tunes. Here the system was fantastic - on all of these songs the vocals came out perfectly and the melodies were just asstirring and evocative. It's been a while since I've really got into the emotion of the music. Very impressed.
3. Epsilon Phase - Global Communication.
For those of you on the Dark Ambient thread in the music section (Testure!) - this is a warmatmospheric tune of swirling sounds and deep bassy melodies. Like the other tunes above, this system played it extremely well.
4. Dave Clarke - Worldwide - CD1 Techno mix.
For those that like this sort of think, Worldwide is a seminal techno mix. The system played this better than the more complex psytrance, although I still felt there was a certain rawness lacking.
5. EZ Rollers.
Some liquid D'n'B - very impressed surprisingly. One of the tracks combined a very deep bassline with quite high female vocals and it came out very well. I was really surprised that standmounts could push out D'n'B properly but they definately did. (Although it should be noted I did have the speakersplaced quite close to the walls and I've heard the Dyns generally need a lot of space). Even so however, I found whatever mid and treble there was to be played quite forwardly and again, I found myself with fatigue.
Overall, I'm pretty happy. I'm interested to see how the Neats will compare though and perhaps I may look for a cable/interconnect that will take away some of the brightness.
On another note - I tried placing the Rega on top of the Nait and noticed no audible difference at all. In fact several times during different tracks I put them apart on the surface (the top of a fairly solid cupboard) and then the CDp on top of the amp, and never did I hear any difference so I'm thinking this may be a psychological thing?Or do you need to leave them stacked on top for a while before the sound quality degrades? I only tried it for a few minutes.
Bjork - Unravel,
5. EZ Rollers.
