Need a compact 60w Class A?
captains log
698
Mid Log, Wales
John Log
Hmmmmm....
It just might be a little bit more than 60w output looking at the power requirements:shock: :shock: :shock: :shock:
Not yer average 13a socket required....
Log:td:
Parkandbike
865
7
Cambridge
Don
European "."="," ie 60kW!
Hmmmmm....It just might be a little bit more than 60w output looking at the power requirements:shock: :shock: :shock: :shock:
Log:td:
loosend
3,596
109
Devon
Are these dimensions and weight correct Keith?
Looks rather large for the weight?
Width x Height x Depth 1250 x 1900 x 1250 mm
Once opened 1850 x 2500 x 1850 mm
Weight 1.500 Kg
loosend
3,596
109
Devon
There are some photos on their website of the amp 'opened' it is big.Keith.
I see another set of specs which makes more sense weight to size ratio :)
Dimension and weight
Width x Height x Depth 1250 x 950 x 1250 mm
Once opened 1850 x 1250 x 1850 mm
Weight 750 Kg
Bit of a monster!!
Parkandbike
865
7
Cambridge
Don
In Keith's link I think 1.500 Kg means 1,500 Kg ( European convention "."="," in UK/US convention 1500 Kg? Perhaps 750Kg is the budget version :shock: .
I see another set of specs which makes more sense weight to size ratio :) Dimension and weight
Weight 750 Kg
Bit of a monster!!
loosend
3,596
109
Devon
Or half of one pir of back breakers!
Purite Audio
6,869
41
London, UK
Keith
When the amp is opened satellite- like, it is bigger than a telephone box, at Munich they had or driving this tiny pair of floor standers!
Keith.
MrSteve
