Nest smart learning thermostat and stand display/controller. Version 3.
Amormusic
3,076
2,617
UK
As title. A neat bit of kit that enables you to set a preferred temperature profile to suit your lifestyle. It also learns how you use it and adapts. Also can be controlled by smartphone so you can turn on the heat in the car on your way back home from being out.
Both a neat gadget, but also a good money-saver. This will pay for itself over time.
Easy to install. YouTube Vids available if you can safely install yourself, or get your boiler person to fit during next service.
Bristol location.
£80 plus post.
I'll add some pics tonight when I go to my storage locker.
Amormusic
3,076
2,617
UK
will this work as is? or will it need a hub
It's the bit that connects to boiler and also the controller/display thingy, so you literally connect it to boiler, plug in the display, download the App onto your phone and you're away.
Sorry forgot to take pics, will do so tonight. But suffice to say fully working and good condition.
Amormusic
3,076
2,617
UK
Forgot this was here bump. Picture added.
Just download the app and you're away.
mazian
