I have an old Velleman K4000 that I am modifying, and I have a query about the NFB circuit.
In the original K4000 circuit the 8 ohm tap is used, and in the later K4040 the 4 ohm tap. The only other relevant change I can see is the resistor in the circuit (R13 in the K4000, and R68 in the K4040. Same resistor, just different numbers).
1K5 in the K4000, and 820R in the K4040, and different transformer taps used.
Does it matter which tap is used, as it is really fiddly to change them, it means unscrewing the back panel, unbolting the transformers, wedging them up off the wires and resoldering the solid and stiff wires. I have to use a 100w iron to get enough heat into the binding posts, and if it doesn't need to be done I would prefer not to do it.
I am also following an upgrade (I hope!) posted in DIYAudio to convert to parametric (?) phase splitter, which means changing to K4040 spec too!
While I am at it I am throwing fairydust resistors and caps at it, but cheap ones. (Anyone remember Mavis the fat fairy in Willo the Wisp? Magic, but common!) I'll post a thread in DIY later, with pics, but I would like to avoid letting the magic smoke out.
Here are the cicuit diagrams.
And the modification.
