I've just bought another cartridge to try out, an AT150MLX. In the manual it suggests using an overhang of 15mm. Now, I have always used an arc protractor calculated using Conrad Hoffman's software. This is printed out using Lofgren A alignment.
My TT, a Debut Carbon, has a spec of 18.5mm overhang. My current arc protractor template uses 18.5mm overhang, in line with the Project specs. with the AT150MLX, how important is it to adjust overhang to 15mm? How would I even do that?
I'm a bit confused as to what to do!
Thanks for any help.
