murray johnson wrote:
...... I'm also more interested in making a phono stage with LCR Eq later this year as someone showed in another thread (thatI can't now find!)
Hi Murray,
I was thinking of getting a fully-assembled (LCR) Cole MM/MC phono stage from DIY Hifi supply in Hong Kong, which is meant to be really good:
http://www.diyhifisupply.com/diyhs_cole.htm
(scroll to bottom of page)
The spec has changed since I last looked a few months ago. They seem to be using a SQ Supermalloy 600 LCR Eq module instead of the S&B LCR one used in the past (they weren't able to get sufficient LCR modules from S&B, I think). It comes with a SQ Supermalloy step up transformer whereas last year you had a choice between ordering it with a basic amorphous core transformer or a S&B TX103.
I was previously thinking of buying this phono stage but I've no idea how this SQ stuff compares to S&Bs. Also, its a bit risky buying something at that price ($1337) without hearing it first, despite its good reputation! This appears impossible without actually going to Hong Kong! Shame though, because with the dollar-pound rate being so favourable, the LCR Cole would only cost about £900 including shipping and import duty (by my calculation). This is substantially less than something like a Noteworthy phonote at £1700.
Another even cheaper option I could consider would be to buy a cheap second-hand Ear 834P MM, chuck out the valves and coupling caps, and wire up something like a TX103.
Returning to the topic of the thread, I'd say using a high quality step up is the best way to go with MC.
