Preamp advice please
kougis
Crete
Manos
Hi all.
I have an Usher r 1.5 and Magnepan SMGc.
I want to buy a preamp (i would prefer with dac). Can you recommend something. Not very expensive!
I prefer used if you have something in mind.
Thanks
THOMO
911
207
58
Western Australia
The Usher 1.5 need a preamp with lot of gain.
A valve preamp will get the best out of them.
Once you hear these amps with a decent valve preamp you will not want to use anything else.
I have two of them and have done a fair bit of experimentation with preamps including the Usher preamp.
The Mystere preamp is a good combination and not too expensive.Or perhaps the Doge 8 .
kougis
Crete
Manos
Thanks Thomo.
Where can I find a used one?
...and about how much will it cost?
THOMO
911
207
58
Western Australia
Look at these direct purchase sites for Doge and Ming Da preamps.
Cattylink
Ornec
China High End
Mystere must have dealers in the UK.
Will cost you a bit more but is worth it.
kougis
Crete
Manos
...and to post a wanted add, I must know what I want. That's why I am asking you to suggest me what is suitable for my setup.
pmac
14,252
298
A budget would help
ldog
