Remote controlled 80 watt per channel Quad Elite Integrated Amplifier.
I bought this amp new less than a year ago, and it is in mint, absolutely unmarked condition, complete with its accessories, all packaging and papers, and transit box. As you can see I haven't even removed the protective foil from the amp's display!
Asking £435. Pickup at Gourock a possibility. Carriage at cost.
The manufacturer states that "the Elite Integrated combines all the qualities of the Elite Pre and Stereo in one single Chassis. Quad has gained an impeccable reputation for power amplifiers, never taking away from or adding elements to the original musical context. A selection of input an output connection and functions are are available in the Elite Integrated complemented by a QUADLINK terminal located on the rear. The Elite Integrated is a pure, indulgent product for audiophiles demanding simplicity in operation"
Gain (line inputs) 37dB (max)
Input Sensitivity 300mV or 775mV
Tape in / out 775mV
Output Voltage 775mV
Output impedance 850Ohms
Inputs 2 x RCA input, Tape In
Outputs 1 x Pre-out, Tape Out
Rated Power Output 2 x 80W, 8Ohms
Frequency Response 20Hz - 20kHz (+/- 0.3dB)
Total Harmonic Distortion <0.005% (at 1kHz)
<0.05% (20Hz - 20kHz)
Signal-to-noise (S/N) 105dB (rated output)
Dimensions (H x W x D) 70 x 321 x 310mm
Net Weight 6.6kg
Tape in / out 775mV
Net Weight 6.6kg
