Funnily enough, I had thought about mentioning those same bass traps that are up for sale on here. As to whether they would be suitable for stats, I would think that if the bass hump is a room acoustics issue, they would be suitable regardless of speaker used. If, however, it's emanating at the speaker, some sort of EQ would probably be of benefit. The other thing is that the sound may change as the new panels/components bed in, seeing as they've only just been refurbed. I've just been looking back at old online reviews, as I was sure I'd read that the 63's have a hump in the lower frequencies and I came across this feedback from a customer of OTA :
Salvatore Sacca: Steve/Ron, Sometimes funny things happen. When I received your “line-equalisers”, I was eager to try them. Woke up early Sunday morning, hooked them up to the speakers, turned the system on and….Whamm!! All of s sudden the image heightened, there was more “air” between the instruments, the high frequencies looked like kind of smoother. I’d say “silkier”, but without losing impact and lightening-fast transient response. Moreover, a very annoying boominess in the 80-90 Hz region – partly due to the amp, partly due to the CD player, and partly to as room mode resonance – well, I can’t say it disappeared, but became tighter and more tuneful.
We’re talking about clearly audible differences, the kind you experience, for instance, when you eventually get the “right” cable, and the change was definitely for the better.
Since you had called the thing “line-equaliser” I thought it was supposed to do exactly that, to wit, gently “equalise” some minor irregularities in the speakers’ response. Now, fast forward to Sunday night, when I checked my emails, got your response and…..well, I leant that the thing was supposed to address a totally different kind of problem – which I happen not to have – and “by chance” solved the peaks at 90 Hz and at 12 kHz, with a slight and gentle rise at 13.5 kHz: which happens to be distinctly what I heard. Well guys, if you really got this result by chance, you are very lucky; on the other hand, if you – as I’m more inclined to think – did it purposely, this is another proof that you know your job very, very well; in both cases, you have a very, very good product, and I can easily say that my system sounds BETTER with the little wonder plugged in.
That said, since you warned me that the results might be system-dependent, I spent last week playing around with a couple of amps I have at hand. Besides the VAC PA45 which I currently use, I tried the Bedini 25/25 and the glorious – really glorious – Quad 11; I am arranging an audition with the PASS ALEPH 3 too, but couldn’t try it yet. Well, I noticed the same differences in all three set-ups. This thing’s definitely a winner. .
Finally, do you know the reason why, for Christ’s sake, people keep on driving these speakers with solid-state behemoths? The other day, listening to the Quad 11/ ESL combo, I thought that, really, they don’t do them like they used to any more: in 50 years, all we got is a backwards move, not forward.
With my warmest regards, Salvatore.
The notes on the Widget can be found here
http://www.onethingaudio.webspace.virginmedia.com/OTA/9152-OTA-MAIN.htm . I don't know if it corrects a bass hump, just that it does some EQing, to `improve' on the measurements of stock 63's.
Hopefully, your experimentation will solve your bass hump, but in case it doesn't, I thought it worth mentioning the widget, as a call to OTA would probably uncover whether or not it changes the bass frequenct curve or not.
Another alternative would be some kind of DSP EQing, which would be useful if you do decide at a later stage to go the seperate woofer/x-over route.
