Do the Quads comes with the overload protection circuit (clamps) to prevent modern ( solid state ) amps from frying the treble panels? If not I suggest you add them pronto.
Arcing a panel is the bane of ESLs. If it happens you will see a spark especially if you turn the lights down. This means the panel now has a hole in it and will need to be replaced/repaired, not cheap and not really a DIY job unless you are very hardcore.
Electrostatic panels do age even if not used. The adhesive that bonds the material that holds charge onto the mylar panels does weaken over time, in fact some poeple just rub graphite on directly and this can wear off.
A 1970s LP12 will be very euphonic and if you like the sound then any upgrades will make it more accurate but not necessarily sound as good. The Hercules board is a good replacement power supply if you need it and gives easy change from 33 to 45 without a manual adapter.
Replace the cartridge if you have no idea what it is and no idea about the state. A Goldring 1024 or similar will do. Do you trust your vinyl to a stylus of dubious history?
The flat belt and crowned pulley were something Linn actually did well. Far better than the stupid round belt on the Michell and Transcriptors decks which were only used as they allowed easy changing of the speed originally by moving the belt onto another width pulley. I cannot comment on other source of the belt but Linn's belts are pricey given what they are but then it is hard to machine a decent flat belt. Much easier and cheaper to do a round profile.
Sounds like you have the making of an interesting system. Enjoy it.
