Exactly… (Does that make a difference?)Yeah but they're ANQOS - Almost New, Quite Old Stock...
Like most of their rangeNo, but be careful with the KR 845s - they don't strictly follow the 845 specification and really only work in KR amps.
KR don't make any amps that use the 845, baffling that they would do that.No, but be careful with the KR 845s - they don't strictly follow the 845 specification and really only work in KR amps.
Ouch! An expensive way to find out :shock:They certainly used to. Stick KR's in a typical Chinese 845 amp = expensive bang.Been there. :x
They really don't want those valves to escape, do they?They certainly used to. Stick KR's in a typical Chinese 845 amp = expensive bang.Been there. :x this was it:
That is a VA350i which uses T100 valves. The nearly identical VA340 uses 300B XLS. All their other amps, old and new, look quite different and none seem to use the 845.They certainly used to. Stick KR's in a typical Chinese 845 amp = expensive bang.Been there. :x this was it:
*Edited to say no thank you thanks to the other guys posts about blowing up things!If the only 845's are made in China, does that mean that KR make theirs there too?http://www.kraudio.com/index.php?option=com_content&view=article&id=46%3A845&catid=4&Itemid=7〈=en
