R3 DAB now sounds great
JANDL100
18,752
4,758
Forest of Dean, Glos
Jerry
I'd given up on listening to BBC Radio 3 on DAB because of the horrible sound resulting from the reduction in data rate.
But I tried again last night - Miaskovsky string quaret 13 - and it sounded bloody good.
Have they upped the data rate again?
JANDL100
18,752
4,758
Jerry
I'm using the digital output from a Videologic DRX-601E (about £70-£80 on eBay) into my Burmester CDP's DAC.
I reckon it sounds better than my old Denon 260L FM tuner. And no hiss
- gawd, I hate FM hiss .....
As long as the DAB broadcaster buggers keep the data-rate up to a decent standard - otherwise it's MP3-time, soundwise.
JANDL100
18,752
4,758
Jerry
..... and of course you get the dreaded "burbles" if the signal strength isn't high enough - or if the weathers bad ..... sometimes in real bad weather there's no signal at all ....
.... but they don't tell you this in their digital radio propaganda do they ?
Chumpy
14,084
Because to me BBC R3 sounds often jolly good on Fm - stereo or mono or processed into 7000 channels - although I record sometimes from Cable or Freeview, I have somehow avoided buying DAB-tuner thing.
I understand that at last usually naff DAB is being superseded towards the end of 2007 ...
RichardG
2,128
18
West of Cardiff, UK
Correct chumpy!
Not sure of the role out timescale...but ALL current dab equipment (including the stuff they're still selling in shops) will be useless. I think the broadcast system will be based on Apple's AAC format? If you want the equivalent of DAB, you're probably better off getting a freeview receiver which is DV-B rather than DAB and will at least be useful for telly after DAB finishes.
It's certainly within the next 18 months...
Edit:
It's called DAB+ (there's imaginative!) and will not be receivable on current DAB equipment. But it's not all bad news as the current DAB broadcasts will continue "until the vast majority of DAB receivers are DAB+ type and OFCOM allows the switch-off of the old DAB transmitters" according to OFCOM themselves. Predicted for around 2010 - 2013....so should get some use out them yet!
E
earl of sodbury
Currently R3 is broadcasting digital at 160KBPS for most programmes and 192KBPS for live concerts - this is lower than when they first went digital...
I recently acquired a Denon TU1800, as it stands, straight into the amp,I can barely tell DAB from FM, except the latter soundsa bit more "radiogram-y".
However, feed the digital output from thetuner through the Stello's DAC and there's barely a fag-paper between DAB and CD
:shock:
It's fucking excellent.
I've tried avariety of DAB tuners and this is the best yet, but the difference a decent DAC makes is exponentially greater than any difference between different models of tuner.
churz, eofs
E
earl of sodbury
Glens of Antrim wrote:
Anybody know if I'd be able to run my DAB tuner from the DAC on my X-Ray v3? And what kind of cable would I need.GofA.
No, you can't - there's no digital input unfortunately...
E
earl of sodbury
Bugger - should have guessed when AM is flogging a stand alone DAC
Got it in one...
chfs911
122
Tuner MD108
Try a Magnum Dynalab 108 on good old FM. Best source I have by far. R3 is superb.
JANDL100
18,752
4,758
Jerry
However, feed the digital output from theDAB tuner through the Stello's DAC and there's barely a fag-paper between DAB and CD
:shock:
Yup - I run my DAB tuner thru my Burmester CDP's DAC - :note:
... didn't know about DAB being phased out though - I hope the new DAB+ boxes have digi outs.
E
earl of sodbury
IfDAB+ happens at-all, it's years away and will run alongside not instead of DAB - first implementation will be via streamed webcasts.
JANDL100
18,752
4,758
Jerry
GofA - get yourself one of those little Beresford DACs - £100 - and you'll probably run your CD player through it too - it may well sound better than your MF's on-board DAC !
HectorHughMunro
5,628
1,642
London, , United Kin
I just bought a Quad FM3 for £65. Absolutely tears apart DAB BBC Radio 3 on a Sony STS DB-900 played through the DAC of a TAG Mclaren AV32. Might actually be even better than a Troughline and is certainly better than the FM4 I was previously using for Radio 3. I was truly shocked at the quality.
JANDL100
18,752
4,758
Jerry
Quad FM3 ? - interesting.
But I think these things need a lot of signal strength (?) - sadly lacking out here in the backwoods of Gloucestershire.
Glens of Antrim
1,973
Norn Iron, , United
Could anyone recommend a DAB tuner with very good FM? I'm using a Pure 702 at the minute & while the DAB's good, the FM is not. Good sensitivity would be a real bonus too (I don't ask for much do I).
Haven't the space for a seperate FM tuner.
John.
JANDL100
18,752
4,758
Jerry
Could anyone recommend a DAB tuner with very good FM? I'm using a Pure 702 at the minute & while the DAB's good, the FM is not. Good sensitivity would be a real bonus too (I don't ask for much do I).Haven't the space for a seperate FM tuner.
John.
^^ You'd be beststarting a thread onthat on the 2 Channel debate part of the forum, methinks !
k23435
