Recommend a kit headphone amp
DPICT
111
North of the north
D
Hi, i am looking for a half decent solid state complete kit preferably from a UK supplier. Budget 80 - 100 quid. Cans are Grado SR80i.
I can solder to a decent standard but would prefer to avoid surface mount components if possible.
Cheers
D
hearingisbelieving
5,674
240
Bendorf, Germany
Hi, i am looking for a half decent solid state complete kit preferably from a UK supplier. Budget 80 - 100 quid. Cans are Grado SR80i.I can solder to a decent standard but would prefer to avoid surface mount components if possible.
Cheers
D
Build a clone of the Grado RA-1 then! If your woodwork skills aint up to much the bung it all in a metal case. You can build a far superior one to the Grado model within you budget as the components they use are cheapp ass shit!
Google Grado RA-1 schematics and Grado Ra-1 clone and you will get the idea.
I am building one right now but in a nice wooden case which a friendly wammer has made for me - just have to route out the cavities now. I use Grado RS2's btw.
