record cleaning fluid diy
robin
Bastard
4,577
926
City of Bradford,
robin
got my purified water, isopropanol 99.9 pure, rabski is very kindly sending me some wetting agent, but whats the best mix ? I think this has been posted before,but a search didn't turn anthing up
robin
Bastard
4,577
926
City of Bradford,
robin
you can use that if you like, but all soap will leave a deposit as it drys, teccy name in a second
rockmeister
18,073
733
Scotland
wetting agent is anything thats breaks the surface tension of the liquid, but photographic chemicals do a 'clean' safe wetting agent imaginatively called wetting agent. A drop of Fairy might be ok too esp if you're vacuum cleaning.
If you were making up a litre, try 890ml distilled water, 100ml alcohol and about 10ml of wetting agent. Shaken, not stirred.
AGrail
2,660
103
Devon
I use x1 part Iso to x4 parts H20 with x3 or 4 drops of Triton (photoflow) for a 100ml small squirt bottle
luckysim0n
1,898
585
Simon
my first attempt at diy cleaner left streaks would that be wrong ratios I used finish diswasher as my wetting agent
lexi
1,811
20
Glasgow, ,
Dishwasher fluid may have caustic, not good.
We don't need salt that is in fairy liquid either,lest you eat your ham and eggs off yer records:D
luckysim0n
1,898
585
Simon
it was distilled water will order some of that photograph stuff and have another go cheers
johnniebaby
18,124
200
Midlands
I have always used purified water from the pharmacy (around £4 for 5l) and have neverhad any streaking problems.
bandit pilot
Comfortably Numb
15,313
2,689
North Nott's
Rick
Go easy with that photograph stuff. You really only need a couple of drops, 3-4 per litre, otherwise you end up in a sudfest.
Willie Garvin
2,753
2,857
Lives near Huddersfield sadly!!
Mick
http://www.tnt-audio.com/clinica/fluids.html
Scroll down to the bottom of the page when you open the link, there are several 'recipes' there & just choose one!!
Reactions: robin
GJO
3,538
138
Kent, ,
Graham
My mix,3ltr purified water,1ltr IPA,5mm rinse aid or fairy liquid,have been using this for > 20 years with no problems whatsoever and don't worry about the salt content as 5mm diluted in 4ltr will have no effect at all,I also make a 2ltr water and 1ltr IPA mix for really bad LP's if the above doesn't shift the crap.
potemkin
2,207
16
wetting agent is anything thats breaks the surface tension of the liquid, but photographic chemicals do a 'clean' safe wetting agent imaginatively called wetting agent. A drop of Fairy might be ok too esp if you're vacuum cleaning.If you were making up a litre, try 890ml distilled water, 100ml alcohol and about 10ml of wetting agent. Shaken, not stirred.
+1 :^
Thats what I use and never have any problems using dishwasher fluid either as the wetting agent
icb40726
