Recording internet radio
C
chris217
Tuned In Radio Pro on Android will do this. You can then export the files to a network share using something like ES File Explorer.
cobbler
2,916
80
Northants
Pete
Freecorder works fine on pc. Be careful you don't tick to add toolbars etc - otherwise get irritating messages. Don't think you get timer function - no doubt have to pay for this.
NAM
5,043
80
Edinburgh, Scotland
Neil
I've worked out how to use Audacity (which has a timer function) to do what I need. It's not a stream that has a url (embedded in a flash-based player) so recording from the soundcard to audacity. Set all levels (web player and soundcard stereo mix output) to max then adjusted the audacity record level with an album played in media monkey that regularly hits 0dB to try and set it so it doesn't clip but so I can record at 16 bit and export to mp3.
Clubsport911
1,814
240
Cheltenham
Steve
I use screamer radio. Bazillions of channels, direct entry of URL, plenty to play with ! Free, low footprint.
Chumpy
14,040
112
Although I have not tried timer-function, I use whenever I am on web (probably 3 times weekly) fine free Audacity and record to WAV/maybe later downgrade-archive-edit the output ...
