Hi
I thought i would just share my latest upgrate with you. Some time ago a replaced the tweeters with the RZZ series as used on the RS5. I then came across some paper in oil capacitors 4.7uf, and as there is only one capacitor required per speaker it was easy to do the upgrade.
After a period of runing in the sound is lush. They were new old stock Plessey in metal cans
Mid/treble is better defined. Well worth the upgrade if you have the inclanation and bits.
Alan
Alan
