SOLD Remton 383 Mk II Phono Stage
Junaman
98
23
28
Near Edinburgh
Craig
For sale is my Remton 383 Mark II Valve Phono Stage. I bought this new from Audio Emotion in 2017 and had it recently checked over by them, so it is in perfect working order. Cosmetically it is in excellent condition (see photos). It comes with original box, packaging and manual and from a smoke-free home.
The stage can be used to run two turntables or arms simultaneously (one MM and one MC). It can be adjusted for a full range of input capacitance and impedance and can run both low and high output MC cartridges.
It currently retails for £1690. I am looking for £725 plus postage (approx. £15). Item will be shipped securely by Royal Mail Next Day Special Delivery (with you by 1pm) or can be collected just north of Edinburgh.
Reviews:
https://www.hifipig.com/remton-383-mk-2-phonostage/
http://www.puresound.be/home/archiv...ay]=27&cHash=6e3dc197cf436ad0d4fd156d81175a94
Details:
Remton Audio 383 MK2 Tube Phono Stage
Get The Real Vinyl Sound.
The MM/MC Phonostage that brings true audiophile performance for an incredibly affordable budget, but keep it quiet, we don't want everyone knowing..................
It is well known that valves can sound much better than transistors, this is especially so with LP reproduction. The LP was developed in the time of valves, and without the warmth and organic nature of valves, transistor phono pre amplifiers can sound uninteresting and hard to listen too.
Designer Alexander Remmer has hand-crafted the 383 MK2 to offer customers with Moving Magnet or Moving Coil cartridges a truly immersive vinyl experience, and one which stays with the listener long after the power switch has been slid to "off"..........
Suitable for MM and MC cartridges
  • Passive RIAA equalization
  • Zero negative feedback
  • Low noise
  • Gold plated Input/output terminals
  • Soft-start DC high voltage supply
  • Hand picked high quality components
  • Toroidal power transformer
  • Frequency response RIAA: 20 Hz to 20 kHz ±0.5 dB
  • Input impedance: from 36 Ohm to 100 kOhm
  • Input capacitance: 0, 47 pF, 100 pF, 147 pF, 220 pF, 267 pF, 367 pF
  • Output impedance: 0,6 kOhms
  • Load Settings: MM 47K, MC 36, 43, 53, 68, 80, 118, 146, 171, 212, 250, 270, 320, 470, 1K
  • Gain: MM: 53dB, MC high: 73dB, MC low: 79dB
  • Tube complement - hand matched 3xJJ ECC83S
Dimensions: 386 x 295 x 85 mm
Weight: 4.5 kg
jbgti
