Resistor biasing
nut
2,060
161
98
Eton wick, berkshire
Phil
I was looking at an amp for sale.
An el34 valve amp.
It has resistor biasing.
Is this the norm for non self biasing amps?
Seems a faff to replace resistors every time the power tubes are changed.
Is is a complex affair to convert to self biasing?
Does it only apply to power/output tubes?
Thanks
toprepairman
1,114
466
Surrey
Henry
I'm guessing here but the implication is that it is resistor cathode bias, which is the same as self bias so the resistors will not require changing.
Jazid
4,585
1,234
And if you do have to adjust the bias manually then there will be trimpots installed somewhere to allow this, so no resistor swapping.
Disarmamant
Certified foo free
627
97
53
Brackley, Northants
Martin
If you are referring to the KEL34 amplifier I posted about, it is self biasing or cathode biased. The output valves have a resistor between the cathodes and ground. The grids of the output valves are tied to ground via high value resistors.
The current flowing in the cathode of the output valves develops a voltage across the cathode resistor which puts the cathode of the output valve at a higher potential than the the grid of the output valve, which is at ground potential. Thus the grid is more negative than the cathode.
The characteristics of the output valves determines the current flowing in the cathodes and thus the cathode to grid voltage, so the circuit is self biasing. There is no need to change the values of the cathode resistors to adjust the bias.
Lurch
5,445
6,028
Chichester, W Sussex
Thanks for the above, it appears that my eyes are universal translators, so that I can read Klingon and other alien languages. Pity this skill didn't include comprehension 😄
  • Haha
Reactions: Ady
Disarmamant
Certified foo free
627
97
53
Brackley, Northants
Martin
In that case maybe you just need to find a copy of the Hitch hikers guide to the galaxy. 😊
nut
2,060
161
98
Phil
It was another valve amp i was contemplationg.
Not the kel34.
The seller said to bias, resistors had to be changed.
35,160
I suggest the seller has probably misunderstood.
No fixed resistors ever need to be changed for biasing purposes, because it's impossible to know what the 'different' value would need to be. At least, not without knowing all the characteristics of each valve and either using a sim program or doing some serious calculations.
The 'resistors need to be changed' may mean that it isn't fixed/auto bias, and that there are variable resistors that need to be adjusted to set the bias.
Reactions: mac72
nut
2,060
161
98
Phil
Confusing.
I didn't realize there were such things as variable resistors.
I have only heard of bias pots.
Jazid
4,585
1,234
Confusing.
In this instance they are the same thing. Bias pots, trimpots, volume, balance and bass and treble control pots are all examples of variable resistor.
Reactions: rabski and mac72
35,160
Yup. A variable resistor is just the umbrella term that I use because I'm old. Technically, anything with three terminals ought to be called a potentiometer, but let's not confuse things even further :ROFLMAO:
pmcuk
4,312
Kensington, London
Not the kel34.
Maybe the meaning was that if you used different types of valves you'd change the value of the cathode resistor, which could be true.
gingerbrown
