ripping & storing 2 versions of CDs
hiacedrifter
233
134
63
Worthing
Is there an easy way to rip and store both highest quality (flac?) and compressed (mp3?) versions of albums? Some albums I have are for "hifi" listening, some are for the kids' mp3 players, some for both.  I rip CDs in dbpoweramp, then in itunes make an mp3 conversion. But i then end up with the album in itunes showing 2 of each track. I guess i need two "libraries" - an mp3 one and a "hifi" one?
jamster
439
210
58
Lichfield
Have two folder structures, one for ALAC* and one for MP3.
Use the multi-encoder function of DBPowerAmp to rip a copy of the CD to each folder in the different format.
https://www.dbpoweramp.com/Help/dMC/multiencoder.htm
Import the ALAC folder into iTunes.
Don't bother adding the mp3s to iTunes.  :)    Just drag and drop them directly to the kids' mp3 players from the folder structure.
* rather than FLAC, as iTunes doesn't like FLAC or at least never used to.
tuga
14,330
6,997
Oxen's ford, UK
Ricardo
Alternatively you can create a new "mp3" iTunes Library, import all ALAC/AIFF, convert to mp3, delete ALAC/AIFF.
But if your kids have iPods then there's the option to sync compressed files:
Blackmetalboon
1,841
1,282
Brighton
It looks like the option of creating a new library for MP3’s, as suggested above, will be the easiest option.
hiacedrifter
233
134
63
Worthing
Thanks for all the help ... i'll properly digest the options later on.  I'm not particularly wedded to iTunes (it just happens to be a nice interface, and I've used since first having an ipod). Are there any more "hifi" options around? I could keep iTunes for mp3s for wife and kids, and have flac files via an alternative.
tuga
14,330
6,997
Oxen's ford, UK
Ricardo
The cheapest option is to add BitPerfect to iTunes and improve its performance:
https://bitperfectsound.blogspot.com/
But iTunes doesn't read FLAC.
There's also Audirvana and JRiver.
rdale
2,806
1,773
178
Gran Canaria, Spain
Richard Dale
I have three users set up on my iMac, a normal ‘rdale’ one and another two others, iTunes_AIFF and iTunes_ALAC. On a large external hard disk there are three top level folders ‘Staging’, ‘AIFF’ and ‘ALAC’ which contain the iTunes collections for each of the three users. The Staging collection is temporary and only contains what I’ve just ripped. When I rip CDs I login as ‘rdale’ and use XLD to rip into the Staging iTunes collection as AIFF. Then I login as iTunes_AIFF and import the new tracks with the iTunes ‘Add to library’ menu option. After that I login as iTunes_ALAC and use XLD to import the AIFF Staging tracks converted to ALAC.
tuga
14,330
6,997
Oxen's ford, UK
Ricardo
Why do you need multiple users?
You can have as many iTunes libraries as you like.
I have one for Jazz, one for Rock, one for Soundtracks, one for Ethnic and Traditional, one for Classical, one for Sacra, one for Opera and for Minimal, and one with Test tracks (from commercial to DIY recordings to test signals to stuff I wouldn't listen for pleasure).
Edit: I open iTunes by holding-down ALT while clicking on the icon; this brings up a Choose iTunes Library dialogue box from where I can select the library I wish to listen from.
rdale
2,806
1,773
178
Gran Canaria, Spain
Richard Dale
To minimise the chance of things going wrong. I don’t use any of the libraries for listening, as I use iTunes only for creating trees of folders with the music tracks in them. The AIFF and ALAC directory hierarchies are on the iMac are copied to various disks in Linux ext4 format which I use for listening.
tuga
14,330
6,997
Oxen's ford, UK
Ricardo
Better safe. :^
iTunes librarian capabilities are quite good as is the file browser. I go a step further than you and use iTunes for browsing, then drag-drop track or albums into HQPlayer.
