RJC Audio Lamina Rack
Vinyl Art
12,480
191
RJC Audio are pleased to announce the introduction of the Lamina Modular Rack System. DSCF1255.jpg by BobC44, on FlickrHewn from solid Oak, the Lamina Rack has been designed to grow with your needs. Starting with a base section of two shelves fitted with Soundcare Superspike adjustable feet to which additional shelves can be added as required. The whole unit is clamped together by two integral tensioning bars, allowing for simple home assembly. DSCF1306.jpg by BobC44, on FlickrAvailable in two widths, 550mm and 1050mm, the Laminar Modular Rack will cope with larger equipment. Height between shelves can be set at 150mm to 350mm in 50mm increments (other heights by request) and can be changed as your equipment develops over the years.Modular, beautiful, value for money and equally at home in your listening room or the lounge, the Lamina Modular Rack may be the only rack you ever need. DSCF1316.jpg by BobC44, on FlickrPrice List (correct at 25/10/2013)550mm x 450mm Lamina Modular Rack2 Shelf Base Unit with adjustable feet – £575Additional Shelf inc vertical supports – £225Additional vertical supports (pair) – £751050mm x 450mm Lamina Modular Rack2 Shelf Base Unit with adjustable feet – £875Additional Shelf inc vertical supports – £345Additional vertical supports (pair) – £75
Vinyl Art
12,480
191
The longer version of the Lamina modular rack is now supplied with shelves made from Oak veneered Birch ply, lipped in Oak.Price remains as above.
Samantha
6,547
121
South Lincolnshire
Samantha
Likey a lot! We have one now in our main demo room and the kit looks fab on it. Beautiful piece of furniture and it works great.
Super value too.
Vinyl Art
12,480
191
If you are coming to Scalford pop along to the Gunroom where I will have an Oak and Spalted Beech Lamina rack on display, it is also for sale at £1300.
dillondwight
