Have you seen this:There is a clipping meter at the bottom of the screen if you turn the volume up to max on the RME it then starts clipping on max volume unless i am hitting the wrong volume menu
Set the output of the main volume to zero db. Then set the main volume to lock. That's it. I personally set my main volume to _4.0 dB. This seems to be the best output level to my Arcam.There is a clipping meter at the bottom of the screen if you turn the volume up to max on the RME it then starts clipping on max volume unless i am hitting the wrong volume menu
For some reason not sure why but tried 100% max volume and 0 db when the music gets going on a peak i get some distortion when the music hits maxim peak so i am thinking i would have to adjust the line level volume below 0 db so it never reaches the max peak .Set the output of the main volume to zero db. Then set the main volume to lock. That's it. I personally set my main volume to _4.0 dB. This seems to be the best output level to my Arcam.
Check if the output has gain stagesFor some reason not sure why but tried 100% max volume and 0 db when the music gets going on a peak i get some distortion when the music hits maxim peak so i am thinking i would have to adjust the line level volume below 0 db so it never reaches the max peak .
will have to read the manual tonight
I thought the output line gain sets automatically to the gear your usingCheck if the output has gain stages
I've sent you an inbox with some instructions highlighted in your manual.For some reason not sure why but tried 100% max volume and 0 db when the music gets going on a peak i get some distortion when the music hits maxim peak so i am thinking i would have to adjust the line level volume below 0 db so it never reaches the max peak .
I’ve just started to read the manualI've sent you an inbox with some instructions highlighted in your manual.
Let me know if you don't come right and I'll find out more info for you.I’ve just started to read the manual
Currently how I have it rigged the RME is XLR to my Yamaha A-S3000 then Co- axis to my OPPO but so far pretty pleased with the RME just understanding it better .Let me know if you don't come right and I'll find out more info for you.
Good stuffCurrently how I have it rigged the RME is XLR to my Yamaha A-S3000 then Co- axis to my OPPO but so far pretty pleased with the RME just understanding it better .
but like using it without the EQ or any bass or treble settings just want a clean natural sound which I am getting just didn’t understand about the volume settings
