I have been thinking for a while about trying to move my system around in my room. Where it is currently there are three possible limitations. Firstly, the right hand speaker is quite close to the side wall giving a slight channel imbalance. Secondly, I could get the speakers further apart and finally the TT and rest of kit is between the speakers.
As I will be packing all my kit up to cart it to Stoke in a couple of weeks time maybe this becomes a good opportunity to consider some different options.
I think I have the luxury of 3 different ‘front wall’ options. The current, the window wall or the fireplace wall. The latter two have alcoves to consider- the window is in a large bay, the fire place with chimney alcoves about 35cm deep.
The speakers like to be about a foot from the wall behind. They would sit either side of the bay or within the chimney alcoves.
Room is fairly square if measured into the bay.
What impact do you think the alcoves would have particularly on bass? Does it make a difference to move the kit from between the speakers ? Presumably many of you have similar features to contend with, where would you put the speakers?
Some pictures to help - my daughter is moveable!
