One of the last of the Leak garage collection. I'm usually quite strong on 'cosmetic originality within reason', however, this was a sad Stereo 20 that had already been hacked about by someone in the past, so there was little point in trying. As I'm possibly going to keep this one, it's also turned into an experiment to see just how far it can go.
The most obvious change from standard is the additional lump of a choke on the top. That's because the power supply has had somewhat of a rethink. This is just more in line with the TL12 Plus circuit, though with some more tweaks. The other main cosmetic difference is decent quality ceramic valve sockets, and rather than self-tapping screws, everything is hex bolts. The chassis and all the transformer covers were sand blasted and powder coated. It's not perfect, because they were really corroded and pitted. Attractive enough though.
Under bonnet shots tomorrow, when it's finished. Pretty much original in terms of circuit, though with a few small niceties. The main change is component specs and layout. This has ended up a bit insane, with Audio Note coupling capacitors, a mix of Audio Note and Kiwame resistors and an awful lot of Duelund and Neotech wire. The wiring layout is also very different, with a lot of care over keeping signals clean and single-point star grounding. An awful lot of time involved, but hopefully it will all work, then it will be fun to see what it sounds like...
