SOLD Schiit Ragnarok Integrated Amplifier
Weeman1973
569
115
63
Cambridgeshire, UK.
Russell
Selling my amazing Schiit Ragnarok Integrated amplifier.
In awesome condition as can be seen by the photographs and sounding oh so sweet, this is not only a wonderful integrated amp but also a fantastic headphone amp offering both single ended and balanced outputs to drive any cans.
I used it to great effect with my LS50 Meta's and indeed Herb Reichart described this combo as the most enjoyable system he'd heard in the 21st century - full review below:
https://www.stereophile.com/content/schiit-audio-ragnarok-integrated-amplifier
Line-level, solid-state integrated amplifier. Inputs: 2 balanced (XLR), 3 unbalanced (RCA). Output power: 100Wpc into 4 ohms (17dBW), 60Wpc into 8 ohms (17.8dBW), 15Wpc into 32 ohms, 10Wpc into 50 ohms, 1.7Wpc into 300 ohms, 850mW into 600 ohms. Frequency response: 20Hz–20kHz, –0.25dB; 2Hz–110kHz, –3dB. Voltage gain: 20 (26dB), 5 (14dB), 1 (0dB) via front-panel switch. Output impedances: loudspeakers, 0.03 ohm; balanced headphones, 0.1 ohm; single-ended headphones, 3.3 ohms. THD: 80dB, 20Hz–20kHz. Power consumption: 75W quiescent, 500W max.
Dimensions: 16" (410mm) W by 3.75" (95mm) H by 12" (310mm) D. Weight: 32 lbs (14.5kg).
I don't have original packaging but it will be very well protected for delivery. Comes with a print out of user manual and power cable only.
Looking for a veritable bargain of £599 including insured delivery (to UK mainland addresses only).
Reactions: hifinutt
rocksteady
Greetings.
Could you possibly send this to Portugal? If so, I suggest you check https://www.parcel2go.com/.
Best regards.
Leonel
Dungtran
