Scrape on speaker dust cap
jon
1,651
58
78
I've just acquired some new speakers. They've got unusual-looking dust caps - think they're floating dust caps, as described here http://www.300guitars.com/articles/dust-caps-the-deal-on-dust-caps-by-anthony-lucas/ - and there's a small scrape/scratch on one of them.
There's pics here http://www.flickr.com/photos/96845896@N03/ Two questions, really - doesn't seem like a likely cause of problems, but unusual-looking things so I don't know if I'm right? Also, does having this type of cap make them easier/harder to change if it does come to that?
Thanks!
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
That is not the dust cap. That is the end of the pole piece. Lots of manufacturers don't bother with a cap.
jon
1,651
58
78
Thanks, and doh - I had wondered if it was the end of the pole piece, but thought it looked a bit dust-cap-like.
Predictable next question, then - would a scratch on the end of the pole piece be a likely problem?
HoopsOnToast
Legend Wammer
11,626
808
Oxfordshire
Rob
Thanks, and doh - I had wondered if it was the end of the pole piece, but thought it looked a bit dust-cap-like.Predictable next question, then - would a scratch on the end of the pole piece be a likely problem?
Nope, not at all. Wont make any difference apart from your OCD :D
jon
1,651
58
78
Thanks! So, if I've understood things right, it's the speaker cone that vibrates (making nice music :) ) while the pole piece is part of the magnetic assembly that generates the force needed for this?
I'll try to watch the OCD ;)
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
Thanks! So, if I've understood things right, it's the speaker cone that vibrates (making nice music :) ) while the pole piece is part of the magnetic assembly that generates the force needed for this?I'll try to watch the OCD ;)
And to dissipate heat in the coil when in use.
jon
1,651
58
78
Thanks - learned something new about speakers, anyway! Sensitivity in the low 80s, and 4ohm - so suspect they may have a bit of heat to dissipate?
Now, after all that I just need to make sure I don't drop them next time I'm moving them round :)
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
Thanks - learned something new about speakers, anyway! Sensitivity in the low 80s, and 4ohm - so suspect they may have a bit of heat to dissipate?Now, after all that I just need to make sure I don't drop them next time I'm moving them round :)
With spec's like that, Just make sure your amp is up to the task ;-)
Chumpy
14,040
112
I from experience/having forked out much in many places advise you suitably-safely to maximise your perception of your stuff/enjoy suitably.
Sometimes stuff that looks naff sounds fine.
I confess that I need my stuff to look brill to sound ace.
