Hi all,
I currently have a second system that I'm upgrading/building and am looking for advice From others that have heard both amps,so they can hopefully comment on the difference between them,and wether the upgrade would be worth it/or not.
The system is at present an Arcam dv139 as source,into a linn kk/d,linn 2250/d driving a pair of linn katan,cables used are Linn Silver and split k400.
I have been looking at upgrading the 2250/d for a pair of lejonklou tundra monos,the first version,and wondered what kind of uplift in SQ I can expect,will it be worth doing.
The 2250 is a fine amp,but feel there's room for better.
I will also be adding a source for streaming,possibly a sneaky ds or maybe an early akurate 0 or 1 and will also be adding a sub to help with bass below 85hz which will give the sound more body and depth.
Hopefully some of you have heard both amps,and might like to comment on the difference between them.
The upgrade amp budget will be around £800 with the assumption that my 2250 will sell for £650+,so a budget of £1400 in total.
I listen at very low levels,as I have a hearing condition which prevents me from listening at higher volume,so don't need a huge power hungry class A,valves are interesting,but not viable in the room available.
If anyone can think of any other amp that is standard case size or smaller,and under 12kgs in weight,that would be a good upgrade from my 2250, recommend away
