Hi all.
Please can anyone help me source a 4 way Phoenix connector for use on a Sherborne LDS2/150B amp?
I have 2 amps but one of the connectors is missing (see picture)
Any help would be greatly appreciated.
Hi and thank you for the reply.
Would you happen to know if this is the same size? I did find one on eBay but then it arrived it was too small. Is the 5mm the distance between the pins?
Thanks.
Not a clue. Never used the things. However, the RS site has links to specs and technical drawings, so I think all the sizes are shown. If you check the RS site there are loads of them shown.
