Linn Owners
Sky Q and AKDSM
Scott mc
116
115
SW Scotland
Hi all,
Having recently upgraded to katalyst and hdmi2 on my dsm
I can get sound through the dsm via sky Q and optical + internal speakers setting on my lg smart tv.
I would like to use arc from tv to dsm but just getting no sound🤯
This is driving me 🥜.
I know it’s maybe not the normal topic but help would be appreciated.
BTW KATALYST is amazing 👍
Moomintroll
3,043
3,718
This help?
ARC - Audio Return Channel​
Only the Klimax DSM / Akurate DSM / Majik DSM with HDMI2 boards (>Sept 2016) plus the Selekt DSM & Series 3 (301) will support this connection.
ARC setting on your Television vary from manufacturer to manufacturer. So please double check your TV setup manual.
Common issues for the lack of ARC audio:
1. The standard Linn DSM can only playback stereo audio. If the TV is set to output Dolby Digital or other Surround format then the Linn DSM will not play this audio and stay silent.
> Make sure the audio output is set to "STEREO"'> If you are using an built-in service to the TV, such as Netflix, Amazon Prime etc, that you control from the TV handset then try a standard aerial TV channel or an external Satellite receiver and find out if you get any audio back from these TV sources.
2. The TV audio setup may be conflicting with itself.> If possible do an "AV RESET" or equivalent on your TV, then setup for Audio format - Stereo and CEC-enabled (CEC can go by different names AnyNet+, Veiralink, SimpLink, Sony Bravia Sync,RIHD, Kuro Link..... etc. Check what your TV call it)
> In the worst case the simplest solution is to do a FACTORY DEFAULT/RESET on the TV. There may be a conflicting hidden setting that is causing all these issues, a Factory default will clear this and allow a fresh connection.3. You are connected to the wrong socket on your TV.> Check the Linn DSM HDMI output is connected to the TV socket that states "ARC"
4. Sony TV's and SKY-Q: It has been reported that this configuration can cause lack of ARC audio. When it does work,sometimes there is a crack/bang noise from the speaker when the system is put to Sleep/Standby.> The solution is to disable HDMI control on the SKY-Q box and power cycle all of the products. (This is primarily an issue between Sky-Q and Sony Tv's communications)5 Playstation5 (PS5): This can confuse the TV and what it is controlling the volume of, (the Linn DSM or PS5).> The solution is In the PS5 setting go into HDMI > Enable HDMI Device Link > Off.
Common issues for the lack of ARC audio periodically muting:
1. Due to the introduction of eARC, some TV have this implements in different ways. The solution is:> if your Linn DSM has the "eARC Mode" option in then turn this OFF> If your TV has the option to disable the eARC functionality, then also turn this OFF
Reactions: Piercro
Scott mc
116
115
SW Scotland
Wow!
Thanks for this reply. I’m away for a day or two, then I’ll get into it.
Thanks again
Scott…
Moomintroll
3,043
3,718
Wow!
Thanks again
Scott…
You’re welcome. Hope it helps, if not come back here. Also, be aware that CEC can cause problems (generally)
’troll
silkie
299
247
63
Saffron Walden
Jon
This thread inspired me to get CEC working with my ADSM in prep for me ordering a new DSM without the HDMI switch built in. Works perfectly! CEC has always been a bit hit and miss but following the guidance above it's working perfectly. My Logitech Harmony remote and TOSLINK cable are now in the junk pile, and I use one responsive remote for everything, the telly remote! Thanks @Moomintroll.
Reactions: Moomintroll
Billz
The man with no Naim
796
895
Edinburgh, UK
I remember having issues when I tried to set up my Sony OLED to my ADSM using HDMI ARC. It worked with SKY-Q via the TV but Streaming services produced no output at all. Also, it did not suit me that when I turned the TV on the sound automatically came through the ADSM. The sound from the TV is pretty good on its own and certainly good enough for normal TV viewing such as the news. In the end I used a toslink fibre optic cable and I am very happy with the sound quality through the ADSM when I do use it. This way, the sound only comes through the HiFi when I want it to.
Reactions: silkie
Celestion300
