Small distortion in sound
Broner
11
When listening to music I occasionally hear a very small distortion in the sound (for only a fragment of a second). It already happens at a low volume and it is difficult to say whether it simply is a very small interruption of the signal or something else. I can't reproduce the distortion by going back to when it happened during a song.
I stream music with spotify, so perhaps this could be the cause but I would like to hear from others whether this is something common when streaming music, or whether it would be worthwhile to check whether the cables are properly connected.
Mind you, it could be that this distortion only comes up once every 1/2 hour - 2 hours.
If you have experience with this, I would like to hear your opinion.
This is my setup: Tannoy DC6T - NAD C356BEE - Arcam RPAC
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
Is the noise possibly some kind of interference from a fridge motor or central heating timer etc? I would be looking down the chain of things plugged into the mains as a starting point.
Broner
11
@bandit no idea, but I will follow up on your suggestion. I can only draw about 3,5-4 kW from the net at one time before everything shuts down. Anyway, it might be the fridge. That's the only thing that really automatically turns on.
EDIT: toyed a little bit by turning on and off my cooking plate (n=10) but that didn't do anything.
@bmtell I only hear myself breathing, birds singing and cars driving in the far distance.
rdale
2,806
1,773
178
Gran Canaria, Spain
Richard Dale
When listening to music I occasionally hear a very small distortion in the sound (for only a fragment of a second). It already happens at a low volume and it is difficult to say whether it simply is a very small interruption of the signal or something else. I can't reproduce the distortion by going back to when it happened during a song.I stream music with spotify, so perhaps this could be the cause but I would like to hear from others whether this is something common when streaming music, or whether it would be worthwhile to check whether the cables are properly connected.
I would have thought it is much more likely to be something to do with your computer than external interference. Your computer maybe gets busy with something every now and then, causing the sound to drop out. But you don't give any details about the computer setup.
Broner
11
It's an old toshiba satellite notebook (6-7 years old I guess). It is only used for spotify but that doesn't mean that it couldn't be busy processing.
rdale
2,806
1,773
178
Gran Canaria, Spain
Richard Dale
I'm not really a Windows guy and so I don't really know how to debug what is going on. Windows machines tend to have 'anti-virus' programs and maybe one of those is doing some epic scan of your hard disk every now and then, but I'm sure other people may have better ideas than I do.
Cable Monkey
9,068
2,084
Birmingham, UK
Henry
Lets remember that this is Internet streaming. If you cannot replicate it with files on your hard drive then it is Internet or your LAN. If you can hear it using those files it might be the laptop. You then need to try an alternative source to narrow it down further.
Broner
11
I will put some cd's in the laptop to test it. If I can isolate the problem to the internet connection or just the computer processing then I can happily ignore the occassional distortions.
Broner
11
... And thanks for all your replies. It will probably take me a couple of days to compare different sources to the sound I hear to isolate the problem as it only concerns a very small distortion (difficult to hear so you're prone to drive yourself crazy when searching for it) that shows up irregularly.
Who Cares?
383
10
23
Or, if you have or can borrow one, try a cdp, completely bypassing your laptop. Or a tuner, or even a radio with a headphone out.
No problem with any of those will point to something to do with your laptop and/or connection.
