Hi all,
Thought I'd have a go at building a small system for Scalford, hopefully I will be lucky enough to get a room.
This will include a small chip amp and a pair of single driver loudspeakers. An approach inspired by IG81 from some of the single driver forums.
The chip amp is a souped-up Velleman K4003. I am using a Hammond 266L25 transformer, Panasonic FC power supply caps, a Russian PIO bypass cap and sintered glass diodes (similar to the 47 Labs Gaincard)
The input caps were Wima MKS polyester films, but they sounded rubbish (sibilant and unmusical) and I replaced them with Nichicon ES input caps - which really let the music breath and let through more tone. Wiring is silver and volume pots are Vishay cermet.
The whole amp works surprisingly well. So here's what it looks like:
and here are some pictures from building it:
I hope you like the pictures and eventually the sound.
Hopefully the carpenter to agree to machine the Baltic Birch panels and there should soon be another update on the loudspeaker end.
Andrew
Andrew
