When songcasting from Klimax system (Exakt kdsm, Klimax Katalyst 350A’s) to secondary system (renew, solos or Majik DSM/ solos) I frequently get audio dropouts. I still have the Kinsky app on iPhone and when the dropouts occur I see a spinning propeller in track progress circle which I was told means it’s buffering. When I contacted Linn support they said it may be a problem with my network or router. I am streaming Flac files from a new Synology NAS. The router is a few years old Netgear (Nighthawk R7000 AC 1900) hardwired to a couple of unmanaged gigabit switches. The Ethernet cables are a mix of cat 5 (in walls) cat 5e and cat 6. My dealer said it can’t be the Ethernet cables. I first noticed dropouts when Songcasting high res 192-24 from Klimax system to secondary system. It does occur with cd res as well and sometimes when songcasting from secondary system to klimax system. On occasion either system can vanish from Linn app home. Last time that happened even though the Klimax room wasn’t visible on Linn app and I couldn’t control it, I could start and stop the song with the remote, and the song showed on the display of the Klimax.
I suspect I’m not the only one to have encountered this problem. Has anyone had similar experience and I would greatly appreciate ideas and guidance on how to figure out the cause and solution
I guess it’s also possible the house is possessed..
