Sonic T project
JamPal
Content Provider
32,265
552
Sussex, West Side
I have a nice extruded aluminium chasis and some gold plated phono's and RCA's.
I also bought a new Pot for the volume. However I realised the volume pot on the Sonic T also turns the thing on and off.
Is there anything I need to be really careful of. Are there special Potentiometers you can buy with a switch mech as standard.
I don't want to stumble into the old Chasis without having all of the right bits to finish the job..
Ben, have you joined yet? Any advice mate?
supercapman
1,313
Bath, , United Kingd
Hi J,
apologies if you have already seen this but his may interest you:
http://www.tnt-audio.com/clinica/t-amp_tweaks_e.html
Happy tweaking
JamPal
Content Provider
32,265
552
Sussex, West Side
I'll seek one out.
I really had planned to have it ready for the bake off, but no chance really.
Ben, are you around on the 30th? There will be some serious kit here.
It's ok guys Ben is not my imaginary friend. He's a mate of mine that is also into HiFi. he promised to drop by and say hi. He also knows about my Sonic T project so I'm sure he'll read this thread.
mosfet
6,194
19
Surrey
A tweak I would have thought worthwhile with the Sonic T, given the TA 2024 chipset uses digital processing, is to copper screen the enclosure. Easily done with copper sheet cut to size or copper tape. Or use a screening can on the TA 2024 in much the same way high end Marantz CD players include EMC screening for improved performance of digital circuits.
JamPal
Content Provider
32,265
552
Sussex, West Side
Keep them comming chaps. I am a sausage fingered novice at all of this. I sell electronics, which doesn't really qualify me to fiddle with them.
mosfet
6,194
19
Surrey
There’s an entire forum devoted to class T and class D amplification here Jampal.
Plenty of design ideas and modifications for the Sonic T depending on your skill level.
Rather than being a ‘sausage fingered novice’ buy yourself a soldering iron kit from Maplins, a desoldering pump and a pair of side cutters - the very basics - along with a couple of electronics kits to practice on (novelty door bell etc) and give it a go!
JamPal
Content Provider
32,265
552
Sussex, West Side
mosfet wrote:
There’s an entire forum devoted to class T and class D amplification here Jampal. Plenty of design ideas and modifications for the Sonic T depending on your skill level.
Cheers mossy.
On the Sausage front I have said kit (well I can noble it from work). The forum pointers are very gladly received.
James.
10k
hi James, Ben here- nice forum btw, never posted on a non-IT one before! I'm sure you've had your sonic-t questions answered already - my psu has got a switch on it so when I finally get around to putting my sonic-t in a box I won't bother with an on-off button! - a bit off topic, but the wife says cheers for reminding me about hi-fi - just when the overdrafts were getting cleared..
JamPal
Content Provider
32,265
552
Sussex, West Side
Hahaha! Sorry mate.
Thanks for comming along, I hope you stick around for some fun. They are a harmless bunch (mostly :D ) and the music section is just getting started. All up it seems to be working out.
James.
subterranean-alien
1,215
Lancashire, , United
Stu
Id go the seperate psu way and use that for on/off purposes. Id look at either a main based unit and use ALW super-regs or a battery based system such as this:
http://tangentsoft.net/audio/ppa/bb/
If you go for a blue alps or similar may I recommend a shunt mod (cant find my diagram :Upset:). Basically this involves two high quality resistors in the signal line and shorting the wiper to earth. Its very simple and very effective.
JamPal
Content Provider
32,265
552
Sussex, West Side
Thanks for all your advice guys.. The project is underway now. Got some bits done tonight. I would really like to have it finished in time for the bake off.
First: I took off the lid (6 Screws, 2 in battery bay 4 under sticky feet.)
Long nose pliers are handy to remove the Volume Pot assembly (only needed if you are re-using it.)
Then I Carefully removed the glue on the board
You need to melt the plastic tabs also
Then I put all of the bits you bought on the table and looked at them for a while
Then I decided to do some drilling instead... Drilled a load of holes in the back panel (no photo's of this as I really didn't want to stop, fanny about and fuck it up.)
Then mounted some of the bits in back plate to see what it looks like so far and make sure everything is straight.
Then I took a load of photo's of the wiring and copied them onto my PC and my home web site so I always had a reference.
Then I had a G&T.
Then I came over here to tell you what I had been up to this evening.
JamPal
Content Provider
32,265
552
Sussex, West Side
I think I will Pete.
I think I'll go for a bit of a Blog on this one. Got to buy some PCB mnounting feet tomorrow and a solder sucker . Watch this space.
James.
OpenSea_0
