Following the discussions regarding my WM-D6 which I brought to the WAM Show, several Wammers have suggested that we have a thread dedicated to Sony Professional Walkmans.
Generally the term “Professional Walkman” covers the WM-D6 and WM-D6C models, but the WM-D3 and the playback only WM-DC2 were also offered by Sony as “Professional” models.
While I would like this thread to celebrate the amazing qualities of these vintage machines, I feel that I should start by repeating the warning I wrote in the “WAM show, Stoke, 2022 photos” thread, in the hope that it may save somebody from an expensive repair or an unusable walkman.
The warning concerns the problems with the Sony CX20084 motor driver chip which is used in the D6C and also in the D3 and DC2 (as well as the DD100 “Boodo Khan” and some other DD series walkmans).
Do not plug any of these walkmans into a non-Sony plug-top DC power supply, even if the stated output voltage is correct for the walkman, or you will probably blow the CX20084 motor drive chip, resulting in the motor running very fast or not at all.
This can happen for one of three reasons.
Firstly, the DC input sockets on the D6, D6C, D3 and DC2 (along with a lot of other Sony equipment from that era) are wired centre pin negative. If you plug in a supply which is wired centre positive (as most sold now are) it will blow the CX20084 chip on the D6C, D3 and DC2 models. It will also damage the internal DC-DC convertor in all of the Professional models.
Secondly, the CX20084 chip was developed in the mid 1980s when all plug-top power supplies sold were of the linear type and delivered a smooth 6V DC output. Nowadays, virtually all plug-top supplies sold are of the switch mode type, which will destroy the CX20084 chip instantly. I have had several D6Cs and a D3 in for repair which have been damaged in this way.
Thirdly, a power supply delivering over 6V (including a set of 4 fresh alkaline batteries) can damage a CX20084. Even if you have an old Sony 6V supply, check the output voltage before plugging it into a D6. For a D3 or DC2, the supply voltage should be no more than 3V.
To make matters worse, in all cases the CX20084 chip is connected directly to the incoming power supply so you don’t even have to press “play” or any other control button to destroy the chip. You will destroy it as soon as you plug the power supply into the walkman.
Replacement CX20084 chips are now becoming very difficult to obtain and very expensive. To make matters worse, there are some unscrupulous sellers selling fake CX20084 chips on various outlets including eBay and AliExpress.
I recommend that you run these walkmans on batteries only, preferably the rechargeable Eneloop Pro types.
Remember, if you see a power supply being sold as "Suitable for the WM-D6C", it probably isn't!
Please see my post on Stereo2Go regarding the problems with the CX20084 chip:
Sony WM-D6C and DD Series Walkmans - WARNING! Read this before plugging in any DC adaptor!
