Sony ta fb940qs top of the range stereo amplifier WHAT HIFI AWARD WINNER!SOLD
F
flo1984
Selling on behalf of a friend Sony Ta fb940qs top of the range stereo amplifier,in fantastic condition with only one scratch on the side.No remote( you can use any sony av remote or universal one for about £10.This beautiful amplifier has a MOS_FET output stage and a good phono stage.
A pleasure to listen to.
Device has been completely checked and tested.What hifi award winner best amplifier up to £500.
The TA-FB940QS/B is an amplifier with a linear phase circuit for SACD (Super Audio CD) It has an output of 2 x 120 watts sinus (DIN) at 4 ohms. An Advanced STD power pack with a toroidal transformer is installed in the device. The super legato linear technique as well as the relay input selector switch are an advantage. The device has 6 audio inputs, 2 switched mains outputs as well as a tape monitor function, a loudness function, a source direct circuit, a balance, bass and treble control. The EON link function in connection with a Sony RDS tuner is very practical. The subsonic and ES filters are of great technical advantage. The device can be mounted on off-center stands.The device is available in black.Collection from London-Stratford or can be send via courier.The price of the amp is £120 ono.
Specifications:
Power output: 80 watts per channel into 8Ω (stereo)
Frequency response: 7Hz to 300kHz
Total harmonic distortion: 0.008%
Damping factor: 500
Signal to noise ratio: 94dB (MM), 105dB (line)
Output: 150mV (line)
Speaker load impedance: 4Ω to 16Ω
Dimensions: 430 x 150 x 420mm
brandonfin
