My system has developed a noticeable buzz (rather than a hum) that it didn't used to have. I haven't changed equipment or cabling - it just appeared one day and seems to have got worse.
Before I look into repairs, I thought I'd canvas thoughts on possible causes other than the need for a repair. The buzz...
- gets quieter as the system warms up
- is on both channels for all sources
- disappears when the preamplifier is muted
- isn't volume-independent, but gets less loud than you'd expect as you turn up the volume
- is still there when all inputs are unplugged from the pre-amplifier
- isn't affected by the ground-lift switch on the back of the pre-amplifier
- is still there with a different mains cable into a different socket
- doesn't change if I switch from a balanced to a non-balanced connection to the power amplifier
- is slightly louder when the balance control is by-passed (strangely!)
I'm thinking therefore that it's a fault in the pre-amplifier (a Plinius M8). Could it be anything else?
Assuming that it is a fault, any recommendations for repairers? Thanks!
