speaker cable length
captain
432
York, , United Kingd
Can any body tell me if having 2 different lengths of speaker cable will effect the sound. I have just moved, and one of the speakers will be about 4 meters from the amp the other just 1 meter. I want to buy asingle runand cut down and terminated my selfto savemoney, but if different lengths do not have an effect the saving will be a lot better on the pocket.
Thanks
Tel
30,402
582
Hove Actually
Kevin
No difference whatsoever.
You would need an imbalance of hundreds of metres (maybe a lot more) before you would notice anything.
Strider
Nothing to see here
5,240
2,538
somewhere or other
Mark
No! You will completely destroy theL/R imaging and soundstage depth. Probably.
JamPal
Content Provider
32,265
552
Sussex, West Side
FWIW, This question has been done a million times.
I use different lengths. there is no difference.
captain
432
Thanks for the info. Can anybody give me some links to sites were I can buy un-terminated lengths. Budget is around the £20-25 a meter, looking for copper any recommendations appreciated. If you know of any thing that will better a cable at that cost for a lot less would also appreciated .
JamPal
Content Provider
32,265
552
Sussex, West Side
Unterminated? Van Damme.
Copper is Copper is Copper old chap .
You could buy enough Van Damme to plait yourself some nice cables for that money. Also buy some sheathing from Maplins while you are there. Just to give ist some extra insulation.
Eds1000
643
if you do you have to use heavier gauge on shorter side,also make sure they are the same colour too.
It's true cos its in my reference book of unknown references.
Chumpy
14,084
Most of audio-consumption/performance - like many things - is 'psychology'.
Depending on the nature of your equipment - electronic and head - most people probably prefer to have equal length loudspeaker-cables - I am one of those.
Eds1000
643
thommo wrote:
If one of the speaker cable lengths is so long that the speaker's actually in another room, I'd say that would affect the sound a fair bit.
not if one ear is red & throbbing from a good self inflicted strike,van gogh sorted his cable problems didnt he,got his stereo seperation right sorted.
Opensea0
