Speaker connection.
muff
151
24
Barry wales, , Unite
dave
Why do some folk connect the speakers on a bi wire terminal only using a single pair of wires. The red positive to top terminal and black negative to bottom terminal. Is there any advantage in this. Hope you understand what I mean.
HansBertil
902
645
113
Sweden
Bertil
I suppose you mean when the terminals are connected with linking strips on the speaker. The (odd) connection is something at least Linn recommend and is of course subject to discussion among the users; is there even a better way to connect? I must say I haven’t heard any difference but, or maybe therefore I might as well use what is recommended by the manufacturer.
muff
151
24
dave
Yes that is the connection.
Jazid
4,576
1,222
I suppose, if poor quality links or bad connectors are used, that your top to bottom method will even up the impedance seen by the crossover.
Will this help? IMO half-way adequate links will remove any such benefit, YMMV.
Paul68
334
1,094
113
West Lothian
My previous speakers had dual posts and I connected my speaker cable black bottom red top. I tried all combinations and I preferred using this method. I replaced the original jumpers with the same cable as my speaker cable.
Reactions: Fullrange
uzzy
Grumpy Old Git
8,316
4,232
NN38TA Northampton
My speakers each consist of three separate enclosures (Bass/Bass Mid/Tweeter.
My choice of wiring could therefore be (excluding tri wiring) the two two terminals, the middle two terminals or the bottom two terminals and a host of diamond options ..
I have no idea if it makes a difference, I did experiment and also did AB in Mono ( in Mono comparing one speaker against the other) .. buggered if I could tell any difference with any combination of connection. However, for those who do, as long as it makes you happy.
Final thought on this - the only time I heard a major difference with connections was when a pal had his speakers wired out of phase .. the look on his face when he heard the difference on proper connection (a move that is clearly audible to anyone)
Reactions: newlash09
icb40726
