I'm fighting what I suspect is a room cancellation effect around 125Hz. The solution is probably sitting nearer the speakers, but it is not possible in my listening room. Having spoken to GIK, it was suggested I move the speakers around a bit to try to generate some reinforcement in the frequency range I'm having problems with (using the Antimode if necessary to trim off any unwanted peaks).
I recall seeing a web site which allows you to input room dimensions and then shows expected frequency response as the speakers and listening position are changed. I wanted to play around with this to get some idea of what might work before lugging the Duos around, but I can't find it. IIRC correctly it was on the site of a US dealer and was therefore restricted to the speakers he sells, but it would be a good starting point. Can anyone remember the site (I tried a search)? Any suggestions (regarding the site) greatly received.
