I used OSMO polyx satin (glossy is type 3011) to finish my IPL transmission line speakers kit. I used ash veneer and the OSMO was so easy to apply by brush. Highly recommended by IPL speaker company.Hi. What is the best varnish to use on veneered speakers? I have covered my diy project in Ash veneer, which is very brittle. What product is the best to use to give a high gloss finish?. Thanks.
Thanks for the replies. What about melamine lacquer?Also, make sure your prep work on the wood is as perfect as you can make it. As I have discovered to my regret. the wax oil finishes like Osmo will ruthlessly expose uneven sanding!
The Danish oil I use has no polyurethane, it’s basically pure Tung oil thinned with white spirit..Osmo oil is really just a wax.It is not hard wearing and will need repairing/rebuffing quite frequently.
Modern Danish oil contains polyeurathane so is not really an oil finish but more of a varnish.It is hard wearing and long lasting.It is not an easy finish to apply well however and has a long drying time between coats.
Most commercial finishes are lacquer.Either single pack precatalysed or two pack acid cat.If you want a gloss finish that is the best option.You can buy it in spray cans but is generally applied with a spray gun.it dries quickly.The thinners used are nasty .
Best to get a professional polisher to do it.
