Speakers for single ended valve amps
EGG 1954
45
WALSALL
GEOFF
I'm new here and not a true teccy - more like an enthusiastic amateur!
Just bought a pair of KT120 Icon MB30 mono blocks after spending a few hours in Leicester with David Shaw. They sound so natural to me. I listen to vinyl, mostly stuff from the sixties and seventies - afraid I am old enough to have bought them first time around.
I'm not new to valves, I upgraded from my ten year old WAD EL 84 kit which I used with Ruark Talisman, very civilised but missing the bottom octave so I use a REL sub. The Ruarks sound OK with the new amp but typical of type I think there may be speakers that can reveal more of what the new amp has to offer. Listen through WAD phono and pre amp. Now I'm looking for a sensitive full range speaker - floorstanding but less than 1m tall.
Any ideas - could spend £3,000 or so
Tel
30,426
656
Hove Actually
Kevin
Something from Fostex or Lowther maybe, any reason you want full range drivers?
EGG 1954
45
WALSALL
GEOFF
My terminology is probably inaccurate - what I mean is speakers that won't need a sub to get down to a realistic bass - rather than single driver full range
EGG 1954
45
WALSALL
GEOFF
M
MJ.
For that budget your options (especially s/h) are pretty much limitless.
Get yourself off to a few bake-offs and see what floats your boat.
Tel
30,426
656
Hove Actually
Kevin
With 16Wpc in triode mode you are going to struggle to find a speaker with seismic bass no matter what the budget.
What speakers did you audition them with?
M
MJ.
With 16Wpc in triode mode you are going to struggle to find a speaker with seismic bass no matter what the budget.What speakers did you audition them with?
I don't think seismic bass was a requirement.
Tel
30,426
656
Hove Actually
Kevin
Full range without a sub means 20Hz to me, you will struggle to achieve that with 16Wpc into conventional speakers.
EGG 1954
45
WALSALL
GEOFF
Nice to get so many replies from a first post. Not after seismic bass - 20Hz subjectively would be fine - I find I listen mainly in ultralinear mode rather than triode, which gives me 27 watts per channel or so - also prefer to buy new - so ..... hope that helps!
EGG 1954
45
WALSALL
GEOFF
David Shaw's demo room has his Kingsound speakers - 8" mid/bass plus HF as I recall - efficient and full sounding - loved acoustic and electric bass on them
Jazid
4,728
1,402
If they were the speakers that made you buy the amps why not get a pair?
Because they are pushing 2m tall and he wants summat under 1m. AN-E fit the bill nicely, but I would say that :)
mmar
3,680
56
North east
mick
something from decware audio radial range rl3 or similar designed by decware specifically to be used with single ended amps check there web site very helpfull amd informative !
alpileanab
