I sold my Avantgarde Unos in 2019 after 17 years of regular use and they sounded as good as the day I bought them in 2002, to the extent that their replacements (2006 Duos) were hardly noticably better sounding. Then in 2020, I replaced the Duos with the latest Duo XDs and again (sightly disappointingly), the new XDs were only marginally better sounding than the 16 year old Duos.
After about 15 years, the Unos developed a slight "scratching" sound from a bass driver and I though one of its 10" woofer may need re-coning. After describing the problem to the UK distributor, I received back from AG details of a simple fix - adjusting a couple of pots on the bass amp board and adding a small resistor to reduce the start-up thump. After this £2 fix, the speakers were sounding as new once more.
Provided speakers arn't over-exerted by excessive volume levels and are kept in good environmental conditions (no excessive temperatures or humidty), they really should last for several decades with possibly replacement of capacitors at some stage.
Electrostatic speakers are probably the exception, in that they do require replacement transducers after a number of years, but are restored to as new sound once this is done.
